Expanded clay/Argile expansée
MessagePosté le: Ven 14 Mai - 16:41 (2010)    Sujet du message: Expanded clay/Argile expansée Répondre en citant
Bryan,
Have you thought about expanded clay as a filler for the polyester resin Question
The only issue I could see now is a technical one: the balls might float on the resin, but beside that, what do you think Question
MessagePosté le: Ven 14 Mai - 16:41 (2010)    Sujet du message: Publicité
Bryan
Prénom: Bryan
MessagePosté le: Ven 14 Mai - 17:30 (2010)    Sujet du message: Expanded clay/Argile expansée Répondre en citant
I still have ideas for alternatives, but the bentonite is fine for the moment. It is interesting to think about what would be required as a damping factor figure, one would have to consider the wavwforms especially the frequencies, that would be affected. As the plinth has to cope with:
a) continuous waveforms, from motor and other moving mechanicals
b) musically derived waveforms from stylus/arm and loudspeakers from aerial intrusion
c) transient waveforms from seismic intrusions
it is a complex situation.
And one has to consider how the damping works, its not just heat/frictional, but dispersion, even re-radiated energy must be considered. Different clays, even micro glass beads are possible.
[samlpes will be sent off next week, now, I can't get to a post office 'til then,] hats off
MessagePosté le: Sam 15 Mai - 07:06 (2010)    Sujet du message: Expanded clay/Argile expansée Répondre en citant
Gentlemen,
I have tried to make a little bit of order in the huge original "damping factors" thread dividing it in various threads.
MessagePosté le: Aujourd’hui à 17:12 (2017)    Sujet du message: Expanded clay/Argile expansée
