Input impedance & capacitance: how to measure
MessagePosté le: Sam 20 Fév - 02:17 (2010)    Sujet du message: Input impedance & capacitance: how to measure Répondre en citant
( wrong formula in the previous message, sorry)
Well, you need an AC millivoltmeter (suitable bandwidth) or a scope (*). A known resistor and an audio generator.
Set generator to f1.
Connect generator and resistor to the amp as follows:
Measure e and Vi; you'll obtain the input impedance Z1 at f1 from 1)
Set generator to f2.
Repeat as above. Now you have two values of impedance, Z1 and Z2 at f1 and f2 respectively.
Obtain C from 2)
(*) A sensitive gadget, capable of measuring few millivolts, if you want to do the trick on phono preamplifiers.
MessagePosté le: Sam 20 Fév - 02:17 (2010)    Sujet du message: Publicité
Richard
Prénom: Richard
MessagePosté le: Mar 2 Mar - 23:45 (2010)    Sujet du message: Input impedance & capacitance: how to measure Répondre en citant
Thank you Piero.
I will try to digest this and even apply it! I have an old Heathkit signal generator. Not sure about reading millivolts, however.
Richard Steinfeld
MessagePosté le: Mer 3 Mar - 12:58 (2010)    Sujet du message: Input impedance & capacitance: how to measure Répondre en citant
Richard a écrit:
Thank you Piero.
Don't mention it, Richard. Smile
MessagePosté le: Aujourd’hui à 12:06 (2017)    Sujet du message: Input impedance & capacitance: how to measure
