L75 vibration scans
Bryan
Prénom: Bryan
MessagePosté le: Jeu 18 Fév - 15:42 (2010)    Sujet du message: L75 vibration scans Répondre en citant
Thought you might like a look at this, accelerometer frequency scans of a bare GL75, vibrated with a drive unit cone fed with sine waves from 100Hz to 1kHz linear scan, corrected for abnormailities in frequency response of drive unit and accelerometer.
© Bryan Wallwork 2010
The arm (at the bearing) is vibrating more than the top plate (all scans to same scales), a case of the tail wagging the dog!
MessagePosté le: Jeu 18 Fév - 15:42 (2010)    Sujet du message: Publicité
MessagePosté le: Jeu 18 Fév - 17:12 (2010)    Sujet du message: L75 vibration scans Répondre en citant
What kind of bearings (V-blocks) in the arm under test, Bryan? Newer brass/quartz ones or the old rubberish stuff?
The arm was resting on the arm rest in the third scan?
MessagePosté le: Jeu 18 Fév - 17:23 (2010)    Sujet du message: L75 vibration scans Répondre en citant
Gentlemen,
I have moved this discussion here Wink
Bryan
Prénom: Bryan
MessagePosté le: Jeu 18 Fév - 18:10 (2010)    Sujet du message: L75 vibration scans Répondre en citant
I bought this deck from a TV repair man, it was his own, and kept it in good condition. He said he fitted new v-blocks, I suggest they are the Technical & General type.
The arm was resting in the arm rest, because I had not put the balance weight in place. I will repeat the test, with and without! Good point. hats off
here it is, slightly different conditions from the first scan, and the arm has a counterweight:
MessagePosté le: Jeu 18 Fév - 19:57 (2010)    Sujet du message: L75 vibration scans Répondre en citant
Interesting scans, interesting indeed!
I wonder if we could venture a guess, ie that those Lenco people put the rubber bearings in their arms after due consideration...
Bryan
Prénom: Bryan
MessagePosté le: Jeu 18 Fév - 20:54 (2010)    Sujet du message: L75 vibration scans Répondre en citant
I'm sure that they did, it seems as though the design was very well thought out, and when properly plinthed with modern materials, can rival most modern designs, and better many. hats off
MessagePosté le: Aujourd’hui à 17:11 (2017)    Sujet du message: L75 vibration scans
