Damping factors
Aller à la page: <  1, 2, 3, 4, 5, 6, 7, 8, 9
MessagePosté le: Lun 11 Mar - 22:00 (2013)    Sujet du message: Damping factors Répondre en citant
Hello Rap,
From my own builds and experiments I can agree that the 80mm Bamboo plinth is less prone to rumble and feedback than the 40mm... Interesting is the dip in the 400Hz region for the 80mm and 800 Hz region for the 40mm. What does it mean actually ?
MessagePosté le: Lun 11 Mar - 22:00 (2013)    Sujet du message: Publicité
Rap
Prénom: Rap
Langue 1: ic
Langue 4: fr
MessagePosté le: Lun 11 Mar - 22:55 (2013)    Sujet du message: Damping factors Répondre en citant
It is because the self resonance frequency of the material is half for double the mass.
But this is actually a good thing as hysteresis damping works better at lower frequencies and mass law dictates a halving in level of amplitude of the vibration through the mass so even better.
Energy transfer will behave similar to having to heat up a pot of water on a stove. 2 times the pot of water and you will have to use 2 times the energy to heat it, simple.
MessagePosté le: Lun 11 Mar - 23:35 (2013)    Sujet du message: Damping factors Répondre en citant
Thanks Smile
I must humbly admit physics and maths were not my favs as a youngster Embarassed , the courses just made me sleepish Mr. Green
Rap
Prénom: Rap
Langue 1: ic
Langue 4: fr
MessagePosté le: Lun 11 Mar - 23:40 (2013)    Sujet du message: Damping factors Répondre en citant
Thanks Smile
Bah, it is maths so easy we call it common sense.
It may not look like much on Bryans chart but 6db is a 4 times more,remember logarithmic scale so if put into non db chart the better attenuation of the 80 mm is obvious to all. That is if the energizing force is the same which given Mass law shows the
charts are not using the same amplitude of input.
But there comes a time depending on the density and internal damping of a material when adding mass starts to work against you through larger coupling area to sound waves feedback through the air and internal coupling of the vibrations
(this is especially true for layered materials that have many internal reflecting planes of variable acoustic impedances)
MessagePosté le: Aujourd’hui à 03:37 (2018)    Sujet du message: Damping factors
Page 9 sur 9
