From Italy my new lenco 75 s 16
vale75
MessagePosté le: Dim 20 Sep - 22:40 (2009)    Sujet du message: From Italy my new lenco 75 s 16 Répondre en citant
This is any pics of my  ex-lenco 75 s 16.
This was the lenco before
I cut the new plinth (I have found the design on web lenco heaven)
I have used MDF 20 mm, the turtable is good condition, but I have intational to modify any part; I have cut the side arm and I have polished the surface of the turntable
I have colored the turntable with metallic red I have used another good material for special effect the cork!
The plinth is painted with special effect spray (granito stone)
I have modified the start  with a switch mounted on the speed 16 turns, I have seen this modification on another site (lenco haven)
To reduce the vibrations the plinth it is covered of cork and the plate supports on 4 socks in cork
I have ended the job with the assembly of the base for the arm, now separated from the plate
I have removed all mechanisms of the arm and have reconnected cables to new golden contacts RCA;
another part
Now I have only one old shell and I have played with of the cork, but task that I will take a shell new with MC ( now I have one commercial MM).
ended now I have new lenco and of the good music , many salutes from Italy
MessagePosté le: Dim 20 Sep - 22:40 (2009)    Sujet du message: Publicité
MessagePosté le: Lun 21 Sep - 09:17 (2009)    Sujet du message: From Italy my new lenco 75 s 16 Répondre en citant
Ciao Vale,
Progetto interessante Okay
Pero' non sono sicuro che tutto il sughero che hai messo sia sul bottone della regolazione delle velocità che sul porta testine sia proprio necessario Wink
Hai potuto paragonare il suono prima e dopo delle tue modifiche Question
vale75
MessagePosté le: Lun 21 Sep - 14:11 (2009)    Sujet du message: From Italy my new lenco 75 s 16 Répondre en citant
Ciao Vale,
Il sughero è solo per estetica. Cool Presto moterò una testina MC e una Conchiglia decente. Okay
Grazie hats off
MessagePosté le: Aujourd’hui à 22:21 (2017)    Sujet du message: From Italy my new lenco 75 s 16
