chip amps
Bryan
Prénom: Bryan
MessagePosté le: Mar 14 Déc - 16:30 (2010)    Sujet du message: chip amps Répondre en citant
I have not been too impressed by the specifications of chip amplifiers, until I saw these. They are based on the TDA 7294, at least 50 watts into 8 ohms, with FET voltage and output stages, with mute, standby and thermal protection built in.
I am going to use them in two loudspeaker projects I'm designing. There will be one amplifier, a crossover and heatsink (mounted externally, obviously) in each loudspeaker box, with a common power supply and frequency shaping amplifier, if needed. I'm calling this set up 'pseudo active'. One system is to connect to a computer, the other as lab speakers. More info on my web site.
These are not expensive projects, they are not intended to replace hifi!!
MessagePosté le: Mar 14 Déc - 16:30 (2010)    Sujet du message: Publicité
